Hello all,
I have following blueprint (minimum example):
The faulty/interesting part starts after the section variables.
blueprint:
name: Outdoor Irrigation
description: Automate outdoor irrigation based on soil moisture and sunlight.
domain: automation
input:
target_soil_moisture_beet:
name: Target Soil Moisture (Beet)
description: The desired soil moisture level for the beet area.
selector:
number:
min: 0
max: 100
step: 5
percentage_per_min_beet:
name: Percentage increase of soil moisture per minute for the beet area
description: Number how much the soil moisture value in percentage increases after one minute of watering
selector:
number:
min: 0
max: 30
step: 1
moisture_sensor_beet:
name: Moisture Sensor (Beet)
description: The moisture sensor for the beet area.
selector:
entity:
domain: sensor
valve_beet:
description: The valve for irrigaiton for the beet area
selector:
entity:
domain: switch
variables:
var_target_soil_moisture_beet: !input target_soil_moisture_beet
var_moisture_sensor_beet: !input moisture_sensor_beet
var_percentage_per_min_beet: !input percentage_per_min_beet
- platform: sun
event: sunrise
- service: switch.turn_on
metadata: {}
data: {}
entity_id: !input valve_beet
- delay: >-
{{ ((var_target_soil_moisture_beet | float(85) -
var_moisture_sensor_beet | float(75)) /
var_percentage_per_min_beet | float(10)) * 60 }}
- service: switch.turn_off
metadata: {}
data: {}
mode: single
The issue here is, that my moisture sensor delivers an invalid input and if I don’t specify a default value, I get following error:
Logger: homeassistant.components.automation.outdoo_irrigation_blueprint
Quelle: helpers/script.py:2002
Integration: Automatisierung (Dokumentation, Probleme)
Erstmals aufgetreten: 21:33:13 (5 Vorkommnisse)
Zuletzt protokolliert: 21:55:47
Outdoo Irrigation - Blueprint: If at step 2: Error rendering Outdoo Irrigation - Blueprint: If at step 2 delay template: ValueError: Template error: float got invalid input 'sensor.tuya_feuchtigkeitssensor_soil_moisture' when rendering template '{{ ((var_target_soil_moisture_beet | float - var_moisture_sensor_beet | float) / var_percentage_per_min_beet | float) * 60 }}' but no default was specified
With a specified default value, the default value will always be used.
If I test the template in the development tools, I get a valid result:
delay: >-
{{ ((states( 'input_number.target_soil_moisture_beet' ) | float - states(
'sensor.tuya_feuchtigkeitssensor_soil_moisture' ) | float) / states(
'input_number.percentage_per_min_beet' ) | float) * 60 }}
Maybe it is an issue, that I receive the result of type “string”?
Last, but not least some informations about the entity:
I just want to calculate a delay, depending on the current soil moisture.
What I tried so far:
- I’m using variables in the template instead of “!input” method
- I added the prefix “var_” for a unique naming of the variables
- I specified default values, when parsing
Best regards!
