I am trying to compare two temperature sensors This did work at one time but I added a second “smart implant”. In the process of adding it, I had to completely remove the original one and then add them both back. It would not “interview” properly unless I did that. I also let the installation do all updates.
Now the template:
will not work. The two sensors are:
and when I test the template I get the error:
I have looked at all the other cases that I could find about this but nothing seems to help.
Note that the template may be working. It is a bit non-trivial to test all conditions but clicking on the “test” button produces the error shown above.
any suggestions would be appreciated.
