Have a sonoff TH16 with temperature, humidity sensor and have problems with sensor updates. Want to make automation to check if update is more then x minutes.
this give me error: TemplateSyntaxError: expected token ‘)’, got ‘b92da_h’
tested automation with other entities and working great, but those “10010” from the entity name causing this error, any clues?
I’d suggest you rename that entity id to something a little more descriptive that does not begin with a number, before you start using it all over the place.
