I get the following error from my template:
File "/usr/src/homeassistant/homeassistant/components/sensor/__init__.py", line 583, in state
numerical_value = float(value) # type:ignore[arg-type]
ValueError: could not convert string to float: '737.0\n}'
<snip>
ValueError: Sensor sensor.solar_battery_to_grid_w has device class 'None', state class 'None' unit 'W' and suggested precision 'None' thus indicating it has a numeric value; however, it has the non-numeric value: '0.0
}' (<class 'str'>)
The template is actually quite simple:
- name: "Solar Battery To Grid W"
unique_id: solar_battery_to_grid_w
unit_of_measurement: "W"
icon: mdi:solar-power
state: >
{% set exported_power_w = states('sensor.power_grid_export') | float(0) %}
{% set panel_to_grid_w = states('sensor.solar_panel_to_grid_w') | float(0) %}
{% if ((exported_power_w + 1) > panel_to_grid_w) %}
{{ (exported_power_w - panel_to_grid_w) | float(0) }}
{% else %}
0
{% endif %}}
I don’t quite get where that spurious bracket is coming from which is highlighted in the error message.
The input templates are the following:
- name: "Power - Grid Export"
device_class: "power"
state_class: "measurement"
state: "{{ max([float(states('sensor.solaredge_modbus_m1_ac_power'), 0), 0]) | abs() }}"
- name: "Solar Panel To Grid W"
unique_id: solar_panel_to_grid_w
state: >
{% set panel_production_w = states('sensor.power_solar_generation') | float(0) %}
{% set house_consumption_w = states('sensor.power_consumption') | float(0) %}
{% set b1_dc_power = states('sensor.solaredge_modbus_b1_dc_power') | float(0) %}
{% if (exported_power_w > 0 and panel_production_w > 0) %}
{% if (panel_production_w <= house_consumption_w or house_consumption_w < 50) %}
0
{% elif (panel_production_w > exported_power_w) %}
{{ (exported_power_w) }}
{% else %}
{{ (exported_power_w + b1_dc_power) | float(0) }}
{% endif %}
{% else %}
0
{% endif %}
