chris-kuhr
(Christoph Kuhr)
January 23, 2022, 7:56am
1
Hi *,
I write a float value like “2.0” as string in an input_text entity.
input_text:
text_thermostat_livingroom_default_day:
initial: "2.0"
--------8<--------
- service: input_select.select_option
entity_id:
- input_select.preset_thermostat_livingroom
option: >
{{ states('input_text.text_thermostat_livingroom_default_day') }}
When I evaluate the state of the input_text entity in a template expansion, the “.0” gets striped off.
Debugging output:
Executed: January 23, 2022, 08:44:32
Result:
params:
domain: input_select
service: select_option
service_data:
option: 2
entity_id:
entity_id:
running_script: false
Filtering {{ states( 'input_text.text_thermostat_livingroom_default_day') | string }}
also makes no difference.
It does not happen with “2.5” for example.
Why is that?
And how can I prevent this?
Best
Ck
Hellis81
(Hellis81)
January 23, 2022, 8:57am
2
This is common with most (or perhaps all) programming languages.
If the value is something.0
then the .0
is removed.
What is this value used for?
chris-kuhr
(Christoph Kuhr)
January 23, 2022, 9:03am
3
Yes, if I store in a float value, but I am explicitly using string to avoid numerical evaluation.
I use this to select a preset with the name “2.0”, not the number.
Hellis81
(Hellis81)
January 23, 2022, 9:07am
4
You probably need something like:
{{ '{:.1f}'.format(states( 'input_text.text_thermostat_livingroom_default_day')) }}
chris-kuhr
(Christoph Kuhr)
January 23, 2022, 9:18am
5
Hellis81:
'{:.1f}'.format(
I tried that but I get the error:
Error: Error rendering data template: ValueError: Unknown format code 'f' for object of type 'str'
Which obviously makes sense…
If I filter states as float, I have the same problem again. “.0” is striped.
{{ '{:.1f}'.format(states( 'input_text.text_thermostat_livingroom_default_day') | float) }}
btw I always use string for this property, throughout any automation and entity.
chris-kuhr
(Christoph Kuhr)
January 23, 2022, 9:35am
6
If I put the expansion in double quotes:
“.0” is not striped off, but I have extra qoutes.
Executed: January 23, 2022, 10:31:17
Result:
params:
service_data:
option: '"2.0"'
entity_id:
entity_id:
and with single quotes:
Executed: January 23, 2022, 10:34:12
Result:
params:
service_data:
option: '''2.0'''
entity_id:
entity_id:
While the same automation working for another room looks like this:
Result:
params:
service_data:
option: 2.5
entity_id:
- input_select.preset_thermostat_lab
entity_id:
Hellis81
(Hellis81)
January 23, 2022, 9:49am
7
I can’t see the same issue.
chris-kuhr
(Christoph Kuhr)
January 23, 2022, 9:54am
8
Yes, but you use an input_number instead of input_text.
