I was trying to integrate a mechanical ventilation using this Mechanische ventilatie in Home Assistant · GitHub and this GitHub - eelcohn/nRF905-API: API webinterface for the nRF905
Since the set preset mode didn’t work as I expected I tried from scratch but even a simple dummy template fan does not work as I expect. So either I don’t fully understand how it is supposed to work or the thing is buggy.
“Dummy” fan:
fan:
fans:
simple_fan:
friendly_name: Simple Fan
value_template: >
on
availability_template: >
on
percentage_template: >
{{ states('input_number.simple_fan_percentage') | int }}
preset_mode_template: >
{{ states('input_text.simple_fan_preset_mode') }}
turn_on:
service: script.ventilation_turn_on_off_dummy
turn_off:
set_percentage:
service: input_number.set_value
value: '{{ percentage }}'
entity_id: input_number.simple_fan_percentage
set_preset_mode:
service: input_text.set_value
value: '{{ preset_mode }}'
entity_id: input_text.simple_fan_preset_mode
preset_modes:
- Stand 1
- Stand 2
- Stand 3
- Stand 4
- Unknown
With 2 helpers:
- input_number.simple_fan_percentage
- input_text.simple_fan_preset_mode
And the script.ventilation_turn_on_off_dummy is just a delay
ventilation_turn_on_off_dummy:
mode: single
sequence:
- delay: 1
Setting input_number.simple_fan_percentage to 10 and input_text.simple_fan_preset_mode to Stand 1, then restarting Home Assistant to have the template fan initialise and read these values, the template fan has following state:
speed_list:
- 'off'
- low
- medium
- high
preset_modes:
- Stand 1
- Stand 2
- Stand 3
- Stand 4
- Unknown
speed: low
percentage: 10
percentage_step: 1
preset_mode: null
supported_features: 1
It does NOT read the preset_mode??? Why, why, why…??? Upon initialization the fan CAN have both a preset activated and an associated percentage set.
If I then set the preset mode of the fan (via the lovelace gui) to Stand 2 this is the state:
speed_list:
- 'off'
- low
- medium
- high
preset_modes:
- Stand 1
- Stand 2
- Stand 3
- Stand 4
- Unknown
speed: Stand 2
percentage: null
percentage_step: 1
preset_mode: Stand 2
The behaviour is the same if I pick any other of the presets
Why is it also updating speed to Stand 2?
Why is it setting percentage to null? I expect it to either don’t touch it, or at least simply re-read it from the defined percentage_template. As said above, a preset_mode CAN (WILL in my case) have an associated percentage.
When I change the percentage, the preset_mode goes to null and the speed gets a speed out of the speed list. This behaviour I understand. E.g. setting percentage to 80 results in state:
speed_list:
- 'off'
- low
- medium
- high
preset_modes:
- Stand 1
- Stand 2
- Stand 3
- Stand 4
- Unknown
speed: high
percentage: 80
percentage_step: 1
preset_mode: null
But how do I prevent the template fan to decide for itself to set percentage to null when picking a preset_mode instead of reading that from a helper (a sensor attribute in a real world situation)?
I understand Just setting a percentage does not correspond with any preset_mode.
However, setting a preset_mode, may (in my case WILL) correspond with a certain percentage, so percentage must NOT go to null… Similarly as with the initialization discussed above.
