Hi, I need some help to create a Fan entity by using the Template fan integration.
I have 3 switch entities from a ESPhome device, the combination of which relay is turned on determine the fan speed.
Off
- switch_01 → off
- switch_02 → off
- switch_03 → off
Low
- switch_01 → on
- switch_02 → off
- switch_03 → off
Medium
- switch_01 → on
- switch_02 → on
- switch_03 → off
High
- switch_01 → on
- switch_02 → off
- switch_03 → on
Is it possible to uses these switches in the Template Fan integration? or do I need to create some other entities first so these can be used in the template? My goal is to create a Tile card that controls my Fan (mechanical ventilation) like in the image below
