I have a DC ceiling fan.
It has 5 speeds.
I have set it up in Home Assistant using a Template Fan to configure it.
The template uses scripts which instruct a Broadlink RM4 Pro to fire the RF commands to control the fan.
It’s almost perfect but I have a couple of things I’m stuck on.
- I can control the speed of the fan using the slider BUT when I set it to Zero% no command is fired off from my RM4 Pro
- I would like to be able to remove the Oscillation option from my fan’s config so the oscillation switch/option doesn’t show up in the controls
- When I turn the fan on, the switch toggles on for a moment and then toggles back off, though it does actually send the power command (single command for an/off), so I can’t see the current status reflected in HA, I’m guessing this requires optimistic mode or something but can’t quite figure it out
- When I open the fan controls I have Two icons that reflect Two directions, my fan uses the same code to switch directions rather than Two separate codes where One is for each direction. I’d like to replace these 2 icons with a single icon that reflects the current direction.
I hope I have made everything clear.
Following is the code I used to configure this fan.
The fan:
fans:
living_room_fan:
friendly_name: "Living Room Fan"
value_template: "{{ states('input_boolean.state') }}"
percentage_template: "{{ states('input_number.percentage') }}"
preset_mode_template: "{{ states('input_select.preset_mode') }}"
oscillating_template: "{{ states('input_select.osc') }}"
direction_template: "{{ states('input_select.direction') }}"
turn_on:
service: script.lr_fan_power
turn_off:
set_direction:
service: script.lr_fan_direction
set_percentage:
service: script.lr_fan_set_speed
percentage: "{{ percentage }}"
speed_count: 5
The speed control script:
alias: lr_fan_set_speed
sequence:
- service: remote.send_command
entity_id: remote.rm4_pro_remote
device: Living Room Fan
command: |-
{% if percentage == 0 %}
b64:scAGAWqeBgAAAVcABaUJvB4KHQsdCgoeCR4KHgkeHgodCx0LHAsdCx0LHAwcCx0LCR8IHwkeCh4JHwkeHQsdCwm8HQsdCh4KCR8JHgoeCR8dCh0LHQscCx0LHQscDBwLHQsJHgofCB4JHwkeCh4dCx0KCrwdCx0KHQsJHgoeCR8JHh0LHQscCx0LHQscDBwLHQscCwkfCB8JHgkfCR8IHx0KHQsJvB0LHAsdCwkeCR8JHgkeHQsdCxwLHQscCx0KHQscDBwLCR4JHwkeCR8JHgkfHAsdCwm8HQodCx0LCR4JHgoeCR4dCx0KHQsdCxwLHQscCx0MGwsJHwgfCR4JHwkeCR8cCx0ABdw=
{% elif percentage == 20 %}
b64:scAAAaaeBgAJvB4JHgodCgoeCh0KHgoeHQodCx0KHQsdCxwLHQscDBwLCR4JHwkfCB8JHxwLCR4dCwm9HQodCx0KCR8JHgoeCR8dCh0LHAsdCxwMHAsdCxwLHQsIHwkfCR4JHwkeHQsJHh0LCbwdCx0LHAsJHwkeCR8JHh0LHQodCx0KHQsdCxwLHQscDAgfCR4JHwkeCh4dCwkeHQsJvB0LHQodCwkeCh4JHgoeHQscCx0LHAsdCxwMHAscDB0KCh4IIAgfCR4JHxwLCR8cCwm+HAodCx0LCR4JHwkeCR8dCh0LHAsdCx0LHAsdCxwLHQsIHwkeCh4JHwkeHQsJHh0ABdw=
{% elif percentage == 40 %}
b64:scB6ALqeBgAHHwkeCR8JHh0LCR4dCwkeCr0cCx0KHQsJHgoeCR4KHh0KHgodCx0KHQsdCxwLHQscDAgfCR8IHwkfHAsJHxwLCR8JvB0LHQoeCgkfCR4JHwkeHQsdCh0LHQscCx0LHAwcCx0LCB8JHwkfCB8dCwgfHQoJAAXc
{% elif percentage == 60 %}
b64:scAGAZKeBgAAAVgABXIJvB0KHgodCgodCh4KHgkeHgodCh0LHQodCx0LHAsdCxwLCR8IHwkeCh4JHxwLHQsJHgm9HQodCx0KCR8JHgkfCR4dCx0KHQsdCh0LHAsdCxwLHQsJHgkfCR4JHwkeHQscCwoeCb0cCx0LHAsJHwkeCR4KHh0LHQoeChwLHQsdCh0LHQscCwkfCR4JHwkeCR8cCx0LCR4JvB4KHQscCwkfCR4JHwkeHQsdCh0LHQodCx0LHAsdCxwLCR8JHgkfCR8IHx0LHAsJHwm9HAsdCh0LCR4KHgkeCh4dCx0KHQsdCxwLHQscCx0LHAwIHwkeCR8JHwgfHQscCwkABdw=
{% elif percentage == 80 %}
b64:scAAAbqeBgAKux4JHgodCwkeCh4JHgodHgodCh4KHQodCx0LHAsdCxwLCR4JHwkeCR8dCgkfCR4dCwm8HQodCh4KCR4KHgkeCh4dCh0LHQodCxwLHQscCx0LHAsJHwgfCR4JHx0KCR8JHh0LCbwdCxwLHQoKHQoeCR4KHh0KHQsdCh0LHAsdCxwLHAwcCwkeCR8IHwkeHQsJHgkfHAsJvB0KHQsdCwkeCR8JHgkeHQsdCh0LHAsdCxwLHQscCx0LCB8JHgkfCR4dCwkeCR8cCwm9HAsdCh0LCR4JHwkeCR8cCx0LHAsdCh0LHAsdCxwLHQsIHwkeCR8JHh0LCR4JHxwABdw=
{% elif percentage == 100 %}
b64:scD+ALCeBgAdCh0LHQoJHgoeCR4KHh0KHQodCx0KHQscCx0LHAscCwkfCB8JHgkfCR4JHh0LCR4JvRwKHQsdCgoeCR4JHgoeHQodCx0KHQscCx0LHAscCx0LCB8JHwgfCR4JHwkeHQoJHwm8HAsdCh0LCR4JHgkeCh4dCh0KHQsdCh0LHAsdCxwLHAsJHwgfCR4JHwkeCR4dCwkfCLwdCh0KHgoJHwkeCR4JHx0KHQscCx0KHQscCx0LHAscDAgfCR4JHwkeCR4JHxwLCR8IvB0LHAsdCwkeCR8IHwkeHQscCx0KHQscCx0LHAsdCxwLCB8JHwgfCR8IHwkeHQsJAAXc
{% endif %}
mode: single
