Template: filter list based on string
Hi.
I tried to wrap my head around this for a while now and am stuck.
What I want to achive is to call a service for all cover entities in the room (area) where a script was triggered by an Echo device.
I managed to get a list of all entities in the same room:
{{area_entities(area_id(states('sensor.letzter_echo')))}}
the result is a list, like:
['light.abc','sensor.efg','cover.xyz',...]
Now I want to apply a filter to the list, so that the list only includes cover entities. I would to that with a string comparison and a select filter, but don’t know how or if I need to go another direction (loop?).
The result should be something like:
service: cover.open_cover
  entity_id: <my template with list of cover entities>
P.s.: I am aware that I can use the list unfiltered, but I’d like to do it in a clean way.
{{ area_entities(area_id('sensor.letzter_echo')) | select('match', 'cover') | list }}
Thanks.
I still need the state of the sensor, as the entity_id is stored within the sensor. So this is the final solution:
{{ area_entities(area_id(states('sensor.letzter_echo'))) | select('match', 'cover') | list  }}
Do you have some kind of secret Jinja documentation? The match test is not in the official documentation…
it’s in the HA documentation :wink:
I had assumed it was a copy-paste error so that’s why I removed the states() function. However now I understand why you were using it. Is sensor.letzter_echo a Template Sensor or is it based on some other integration?
A template sensor that checks which Echo media player entity was last triggered.
It would be really nice to have one single templating documentation. A christmas wish for the man that has everything :wink:
So you want us to recreate the 100+ page jinja documentation every new release of jinja because you can’t be bothered to look in the link that we point to from the HA templating documentation?
Don’t take everything so serious :wink:
