Template for timer
Brief description of device or service
Option to template the Home Assistant timer service.
This does not seem to be possible at the moment. I started this topic in September, but so far, me and other community members did not find a satisfying solution for this.
Example
input_datetime:
  set_timer:
    has_date: false
    has_time: true
timer:
  template_timer:
    duration: "{{ states('input_datetime.set_timer').split(':')[0] | int }}:{{ states('input_datetime.set_timer').split(':')[1] | int }}:00"
When I set set_timer to 3:20, the equivalent to duration will be 3:20:00; this should be valied for a timer, correct? However, it does not work.
The workaround I have found is pretty disappointing: I create an input_select for different times (current one has times in 15 minutes intervals from 00:15:00 to 03:45:00). This works, but it is not very flexible).
automation:
  alias: What's wrong with this
    platform: state
    entity_id: input_boolean.WHATEVER
    to: 'on'
    service: timer.start
    data_template:
      entity_id: timer.WHATEVER
Thank you! That solution works perfectly.
