Hi everybody,
I have two 1000l rain water tanks in my backyard. I finally got around to installing an ESPHome
with HC-SR04
ultrasonic distance sensors (well, one for now, still testing).
I’d like to do two things:
- automatically convert the reading(s) (in
meters
) to how much water is left (inliters
) - run automations when water levels above/below certain points (I got this figured out already)
I got this data (water left in liters compared to reading in meters)
- 960 - ~0.06
- 900 - ~0.1
- 850 - ~0.15
- 800 - ~0.2
- etc.
I took measurements in 50l steps (displayed on the outside of the tanks). There is about 0.05m / 5cm distance per 50l water level. Unfortunately, this is not an exact value, but then again, I don’t need to know the exact amount of water that’s in there. ~10l accuracy is fine.
Question
How can I convert the readings via Home Assistant and display the water level in liters? It might be due to doing this in the noon sun for way too long, but I cannot figure out the formula. I do know that 100l ~50l = ~0.05m. But is there a way to automatically return this value, instead of using an enormous if/else if statement via template_sensor
I would now do something like
sensors:
left_tank:
friendly_name: "Linke Tonne"
unit_of_measurement: "Liters remaining"
value_template: >
{% if states("sensor.linke_tonne") <= 0.06 %}
950
{% elif states("sensor.linke_tonne") > 0.06 and <= 0.1 %}
900
{% elif states("sensor.linke_tonne") > 0.1 and <= 0.15 %}
850
# etc. etc.
{% else %}
ok
{% endif %}
This template is not accurate (damn you, sun!!), but I hope you understand what I mean. If I figure out the actual template, it’d work. But it’d require me to create and elif for each 50l (or 0.05m) interval. Instead, I am sure there is some smart formula to mathematically use the sensor.linke_tonne
value to convert it into the equal amount of water left. Obviously, the following is not it, but just as an example
sensors:
left_tank:
value_template: >
{% states("sensor.linke_tonne") | float / <something> * <something_else> | round(2) %}
Thank you for your help.
