Template gives error in config.yaml
i’m trying to work with templats, what i want is do a count on my door and window contacts.
when i check the template in the template editor, it is working, but when pasting the code to the config.yaml. it won;t load.
what do i do wrong ?
sensors:
    sensors:
      contact_count:
        entity_id: sensor.count
        value_template: >
          {% set binary_sensor = [
            states.binary_sensor.voordeur,
            states.binary_sensor.achterdeur,
            states.binary_sensor.raam_voor,
            states.binary_sensor.raam_achter,
          {{ binary_sensor | selectattr('state','eq','on') | list | count }}
When you run Configuration Check, what is the error message produced?
You do have an entity called sensor.count?
I have found the solution, i need to delete
from my sensor, after that it worked, and i have a new sensor in my entities, i came to this with the post from francis.
Why did you originally include this line in the configuration?
I have the impression you do not understand the purpose of including/excluding this line so here’s how it works:
What it instructs Home Assistant to do is to monitor sensor.count for changes to its state. When its state does change, the value_template is evaluated and sensor.contact_count is updated.
If sensor.count doesn’t change state or rarely changes state (or doesn’t even exist), then sensor.contact_count is never, or rarely, ever updated.
By removing entity_id: sensor.count it makes Home Assistant (on startup) inspect the contents of value_template and identify all the entities it contains. It will then monitor all of these entities for state-changes. That means it will monitor the binary_sensors you have listed in the value_template.
Thanks for the info, now i know why it work like it works now.
Where can i find that info, the documentation isn’t realy clear about that.
Review the Template documentation, specifically this section: EntityIDs
