trying to implement this:
https://www.home-assistant.io/docs/configuration/group_visibility/
we read about the data_template containing templates for both entity_id and visibility set through a dedicated script. Which makes things even more complicated than the automation I currently use…
- alias: 'No dev tools at startup HA'
id: 'No dev tools at startup HA'
initial_state: 'on'
platform: homeassistant
event: start
condition:
- delay: '00:00:15'
- condition: state
entity_id: binary_sensor.mode_developer
state: 'off'
- service: group.set_visibility
entity_id: group.developer
visible: False
entity_id: group.developer_links
visible: False
# - delay: '00:00:05'
# - service: script.mode_normal_direct
# - delay: '00:00:03'
# - service: script.opstart_direct
- condition: state
entity_id: input_boolean.notify_developing
state: 'on'
- service: notify.notify
message: >
Dev mode - Dev mode visibility set to false at setup
would have hoped for this possibility:
initial_state: 'on'
event: start
condition:
- delay: '00:00:15'
# - condition: state
# entity_id: binary_sensor.mode_developer
# state: 'off'
data_template:
visible: {{ is_state('input_select.mode', 'Developer') }}
data_template:
- condition: state
state: 'on'
data_template:
message: >
Dev mode - Dev mode visibility set to {{ is_state('input_select.mode', 'Developer') }} at setup
Any thoughts if that is anywhere near correct? If not, we might need a feature request…
Cheers,
Marius
