Template help... input helper to local time
'{{ ((states("input_number.varme_pause_timer") | float * 60.0) | int) | timestamp_custom("%H:%M:%S", False) }}'
this output is 00:90:00
how do i add 90 minutes (template) to local time fx. 21:30:00 + 90 minutes = 23:00:00
"{{ now() + timedelta(hours = states('input_number.varme_pause_timer')|float(0)) }}"
Thanks , but it returns with
TypeError: unsupported type for timedelta hours component: str
Fixed in post above… I accidentally left off the float filter.
Thanks ! I change HOURS to MINUTES - and it almost perfect
I get this output : “2021-10-20 20:06:00.015044+02:00”
how do I get only “20:06:00”
You can control the format of the output by using strftime(format)…
"{{ ( now() + timedelta(hours = states('input_number.varme_pause_timer')|float(0) )).strftime("%H:%M:%S") }}"
thanks, but i get this
UndefinedError: ‘datetime.timedelta object’ has no attribute ‘strftime’
Double check to make sure you got the parentheses correct. You need one before “now()” and two after “|float(0)”
I have added spaces after and before the parentheses in the post above to make it more visible.
now it works !!! THANKS - you’re cool :slight_smile:
“2021-10-21 00:26:38.266037+02:00”
“00:26:38”
