Template help!
Hi all,
I need some help getting information out of a sensor in template form. I want to have the message parts only, but I don`t know how.
This is what I have:
{{ state_attr('sensor.sl_train_status_sensor_hasl_trafik', 'events')}}
It shows all info under events.
The sensor information:
api_result: Ok
scan_interval: 300
refresh_enabled: true
attribution: Stockholms Lokaltrafik
status_icon: mdi:clock-alert-outline
events:
  • EventId: 24319
    Message: >-
    Förseningar på upp mot 30 minuter för Pendeltåg linje 40, 41 och 42X mot
    Södertälje centrum/Älvsjö/Nynäshamns centrum på grund av växelfel vid
    Häggvik.
Best regards
Thekholm
Maybe
{{ state_attr('sensor.sl_train_status_sensor_hasl_trafik', 'events')[0].Message }}
but to be sure, put {{ state_attr('sensor.sl_train_status_sensor_hasl_trafik', 'events')}} in the template debugger to see the json output
Thanks, that worked!
Is also possible to display some of the message (not the hole message).
Best regards
Thekholm
The message itself is a single string.
What part on the message are you looking for?
Ok,
Sometimes the message is to long, but I can live with that.
Many thanks
Thekholm
