Hi, i just created a binary sensor from a switch and encountered two glitches:
- If you change the sensors device class after creation (show as), you cannot unset the device class afterwards (or set it to none)
- If you set the the device class to power, its state is displayed as detected/clear instead of on/off
Is this a known issue? I just worked around by manually recreating helpers
