Template history_stats hours minutes
Hi Iam using hassio I would like to see in different format the time, but I could not set the right template, maybe somebody can help on this.
The time is show in this fromat : 2.41 h, but I would like to see in this format 2:24
Is that posibbile to write sach template ?
  • platform: history_stats
    name: Boiler On Duration
    entity_id: switch.boiler
    state: ‘on’
    type: time
    start: ‘{{ now().replace(hour=12).replace(minute=0).replace(second=0) }}’
    duration:
    hours: 24
    value_template: '{{ states.sensor.boiler_on_duration.attributes.value }}
Capture
Thx !
Did you ever resolve this?
I have the same problem…
Not yet :frowning:
    sensors:
      time_at_work_rounded:
        value_template: "{% set hours = states('sensor.time_at_work') | float %}
        {% set minutes = ((hours % 1) * 60) | int %}
        {% set hours = (hours - (hours % 1)) | int %}
        {{ '%02i:%02i'%(hours, minutes) }}"
this works for me now
Thx for the script
Also works for me
Thx was looking for readable time format as well.
