Template if date is equal or after current date
Hi
can anyone help me with what is wrong with this template. want to show sensor in my sidebar where the date is either equal or after current date. the sensor have a timestamp state.
        chores: |
            {% set sensor_entities = [
              'sensor.clean_doors',
              'sensor.clean_drain',
              'sensor.clean_fridge',
              'sensor.clean_behind_furnitures',
              'sensor.clean_humdifier'
            {% set current_date = now().date() %}
            {%- for sensor in entities if states(sensor) < current_date.strftime('%Y-%m-%d') %}
                {% set chore_name = state_attr(sensor_entity, 'friendly_name') %}
                {{ "Overdue Chore: " + chore_name }}
              {% else %}
                {{ "No overdue chores today." }}
            {%- endfor %}
Not sure if it actually works, but it seems, at least that
should be
for sensor_entity in sensor_entities
then it says this
Never use screenshots for code :wink:
I guess you forget to change if states(sensor) by if states(sensor_entity)
Now it shows all the sensors is overdue… is that something with the date format
the humdifier sensor state is formated like this
2023-08-02T13:00:51+00:00
You are comparing strings that do not even have the same format.
Try
        chores: |
            {%- for sensor in entities if as_datetime(states(sensor)) > now() %}
              {% else %}
            {%- endfor %}
Optimized
        chores: |
          {%- set entities = [
          {%- for name in expand(entities) | selectattr('state', '<', utcnow().isoformat()) | map(attribute='name') %}
            Overdue Chore: {{ name }}
          {%- else %}
          {%- endfor %}
Nice, but I doubt the else will work :wink:
Now, it didn’t do what I think the OP wanted it to do, either… Looks like bits and pieces of code patched together without actually understanding how it works.
Yes it will. That’s normal syntax, just rare
if I paste this in template test
chores: |
            {%- for sensor_entity in sensor_entities if as_datetime(states(sensor_entity)) > now() %}
              {% else %}
            {%- endfor %}
It says no overdue chores today
but at least clean_humdifer is the state 2023-08-02T13:00:51+00:00 , so it should show…
If I change the > to < it show all sensor…
What dates do those sensors contain?
Dates when cleaning is due, or…
What are the date from the other sensors?
Overdue should be using < because lower than now() is in the past. Greather than (>) now is in the future.
Did you try the template I posted?
@petro I tried it, and it complains about a missing {% endfor %}
Seems you accidentally used {% endif %} instead of {% endfor %}
Your example in the screenshot helped me in finding out what what was wrong. Good to know you can use {% else %} in a for loop
when i try it in template i get an error
TemplateRuntimeError: No filter named ‘name’.
The sensors contain due date example
sensor.clean_humdifier state: 2023-08-02T13:00:51+00:00
sensor.clean_doors state: 2023-10-28T15:59:57+00:00
i tried just using only one sensor, it shows it correct then
           {% set sensor_entity = 'sensor.clean_humdifier' %}
            {% set sensor_state = states(sensor_entity) %}
            {% if sensor_state %}
              {% set sensor_date = sensor_state %}
              {% if sensor_date <= current_date.strftime('%Y-%m-%d') %}
              {% else %}
              {% endif %}
            {% endif %}
Fixed
Thanks. Now it says No overdue chores today but it should show these to
what’s your current time? Do {{ now() }} in the template editor and paste the results here
2023-11-06 15:45:56.601114+01:00
You should use < here
As a chore will be overdue if the sensor datatime is lower than the current datetime
You said before it shows all then, what is the state of a chore you wouldn’t expect to show up (so is there a chore which is not overdue yet)?
