Trying to add an automation that sets the required charge needed to Octopus Intelligent. However it seems I can’t run the template in the service call to number.set_value the way I though I could…
This should set the Octopus required value to the max value needed - State of charge of the car with a minimum value of 10% and a max of 80%
service: number.set_value
entity_id: number.octopus_energy_a_533ea5d2_intelligent_charge_limit
value: >
{% set maxVal = 80 %}
{% set state = maxVal - states('sensor.enyaq_battery_level') | int %}
{{ min(maxVal, max(state,10)) }}
Just get an error of
Message malformed: must contain at least one of below, above.
