Currently it is not possible to use templates in a tap action, for example in an URL.
For some purposes it can be very useful to use attributes of an entity inside a URL.
Most core dashboard cards do not support templating.
You can call a script with your tap action where you can template all the things.
Yes I’m familiar with the script workarround. But it doesn’t work if you want to open an URL outside Home Assistant. Isn’t it?
I think templating inside a tap action is something that wouldn’t benefit a lot of people, sorry to say. And with my little knowledge I wouldn’t be sure, if that isn’t a security problem as well…
Nonetheless, is it just a link you want to template? Than use the markdown-card. Fully templatable and works like a charme.
Like this:
- type: markdown
content: >
{% set mylink = "https://home-assistant.io" %}
[My templatable link]({{mylink}})
You get the idea, I only set mylink as an example. You’d just template the link with whatever you want to set in the link.
Thank you for your reply!
I don’t see a reason why this can be a security risk, it’s just a simple link with a variable inside. With tools like PowerShell or other scripting language, this is normal behavior. For efficiency you will use variables much as possible.
I was already familiar with the Markdown workarround. Thanks!
Yeah, as I said, I’m not sure, but using templates in some kind of action just doesn’t feel right.
Any luck with this? I am trying something similar with my card that is supposed to return what is for dinner that night.
show_state: true
show_name: true
camera_view: auto
type: picture-entity
entity: sensor.mealie_todays_meal
camera_image: camera.camera_mealie_todays_meal_image
tap_action:
action: url
url_path: '[[[ return states["sensor.mealie_todays_meal_navigation_url"].state; ]]]'
card_mod:
style: |
ha-card {
max-height: 100px !important;
overflow: hidden;
display: flex;
align-items: center;
justify-content: center;
