Template in timer
Hello everybody.
I have this timer.yaml:
time_warm_floor:
  name: Теплый пол выкл через -
  duration: '05:00:00'
Its working, but I need to enter this parameter manually from Lovelace. I add on input_datetime.yaml:
  input_time_timerwarmfloor:
    name: Таймер теплого пола
    has_date: false
    has_time: true
I change the timer parameters to:
time_warm_floor:
  duration: '{{ states("input_datetime.input_time_timerwarmfloor") }}'
And I get a configuration error:
Invalid config for [timer]: offset {{ states(“input_datetime.input_time_timerwarmfloor”) }} should be format ‘HH:MM’, ‘HH:MM:SS’ or ‘HH:MM:SS.F’ for dictionary value @ data[‘timer’][‘time_warm_floor’][‘duration’]. Got ‘{{ states(“input_datetime.input_time_timerwarmfloor”) }}’. (See /config/configuration.yaml, line 9).
Help me please.
The duration does not support templates. Please refer to the documentation:
Hi, I achieved this with two automations and a script.
The sliders and countdown timers are in my lovelace.
This first Automation turns on device and starts the script.
  - entity_id: binary_sensor.pyronix_motion_detector_back_garden
    platform: state
    to: 'on'
  condition:
  - condition: or
    conditions:
    - before: sunrise
      condition: sun
    - after: sunset
      condition: sun
  - entity_id: switch.sonoff_basic_back_garden_light_cmd
    service: switch.turn_on
  - service: script.1588678566870
  mode: single
'1588678566870':
  alias: Back Garden Security Light Timer
  sequence:
  - data_template:
      duration: 00:{{ states.input_number.security_lights_minutes.state | int }}:{{
        states.input_number.security_lights_seconds.state | int }}
      entity_id: timer.security_light_back_garden
    service: timer.start
The second automation r=triggers when the timer called for in the script finishes.
- id: '1588679946447'
  alias: Back Garden Security Light off /  reset
  description: ''
  - event_data:
    event_type: timer.finished
    platform: event
  condition: []
  - data: {}
    service: switch.turn_off
  mode: single
yaml
### INPUT BOOLEAN NUMERIC ###
input_number:
  security_lights_seconds:
    name: Security Lights ON Timer S
    initial: 30
    min: 0
    max: 60
    step: 1
    mode: box
  security_lights_minutes:
    name: Security Lights ON Timer M
    initial: 0
    min: 0
    max: 10
    step: 1
### TIMERS ###
timer:
  security_light_back_garden:
    icon: mdi:timer-outline
Nice, but what if you only want the lights on when the illuminance of the sensor is lower than X lux ?
