I’m pulling my hair out why this isn’t working: I have a flow that triggers and I want to send an attribute using the notify service. The following works fine in HA Automations but not in node-red:
The call service node doesn’t not render jinja templates. You have to fetch the state before the call service set in a flow context or use the incoming message with moustache template, look at the call service info tab. If you have latest version (not sure yet I have to check) you can use jsonata to get the state without consulting in a previous node.
