I’m trying to make a one light in a group of lights be set to twice the brightness and the same color temperature as the others. I followed this post (which doesn’t cover CCT lights) to get the following code:
light:
- platform: group
entities:
- light.tisch_fenster_n
- light.tisch_raum_n
- light.adj_verlangerung
lights:
adj_verlangerung:
friendly_name: "Adjusted Verlangerung"
value_template: "{{ states('light.tisch_verlangerung_n') }}"
turn_on:
service: light.turn_on
entity_id: light.tisch_verlangerung_n
turn_off:
service: light.turn_off
set_level:
brightness: "{{ brightness * 2 }}"
set_temperature:
value: "{{ color_temp }}"
This works fine for the brightness part, but the color temperature of light.tisch_verlangerung_n
does not get adjusted. Instead I get this error every time I try to adjust it:
Logger: homeassistant.helpers.script.adjusted_verlangerung
Source: helpers/script.py:405
First occurred: 19 September 2022 at 19:35:08 (97 occurrences)
Last logged: 00:17:06
Adjusted Verlangerung: Error executing script. Invalid data for call_service at pos 1: extra keys not allowed @ data['value']
Adjusted Verlangerung: Error executing script. Invalid data for call_service at pos 1: must contain at least one of entity_id, device_id, area_id.
What am I doing wrong?
