I’m trying to get rid of this error in my log: [homeassistant.components.template.light] Received invalid color temperature : 0. Expected: 0-500
I think I narrowed the problem down to my template lights, particularly the setting for temperature_template. I’ve been trying to fix the error, but no luck so far. This is my latest attempt:
temperature_template: >-
{% if state_attr('light.keukentafel','color_temp') == 'None' %}
{{ states('sensor.colortemperature')|int if states('sensor.colortemperature') != 'None' else 330 }}
{% else %}
{{ state_attr('light.keukentafel','color_temp') | int }}
{% endif %}
I think the errors occurs because both light.keukentafel and sensor.colortemperature are not available yet at startup. So I was trying to compensate for that, but I just keep adding if-statements without any success.
My work around was to basically set the temperature_template to the light’s min_mireds if it was None.
"temperature_template: {{ state_attr('light.office', 'color_temp') | int if state_attr('light.office', 'color_temp') | int > state_attr('light.office', 'min_mireds') | int else state_attr('light.office', 'min_mireds') | int }}"
The temperature_template has to be between min_mireds and max_mireds
def _update_temperature(self, render):
"""Update the temperature from the template."""
try:
if render in ("None", ""):
self._temperature = None
return
temperature = int(render)
if self.min_mireds <= temperature <= self.max_mireds:
self._temperature = temperature
else:
_LOGGER.error(
"Received invalid color temperature : %s. Expected: 0-%s",
temperature,
self.max_mireds,
except ValueError:
_LOGGER.error(
"Template must supply an integer temperature within the range for this light, or 'None'",
exc_info=True,
