I need to build a template light to control a physical lamp that can assume “infinite” brightness levels and doesn’t return the current brightness. I have a rest endpoint for brightness up and another one for brightness down.
I tried handling the current brightness using a local variable of a template light, but due to the infinite levels, this just doesn’t work: after a few uses (go up and down the brightness levels) the local variable becomes out of sync with the actual brightness of the lamp.
What would be the best way to model such light?
In my mind, I just need a template light that has a couple of buttons (brightness up and brightness down) without presenting any brightness level.
The same light has also three color temperature levels, that being discrete, I can handle with a local variable.
Thanks!
