jchh
((not John))
September 11, 2023, 9:17am
1
I have this binary sensor:
- name: "Hive heating doors/windows open"
state: >
states.binary_sensor
| selectattr('entity_id', 'search', '(doors?|window)_contact')
| rejectattr('entity_id', 'search', 'bedroom_[a-z,1]|ensuite|front')
| selectattr('state', 'match', 'on')
| list
| count
attributes:
influence: >
| sort(attribute='name')
| map(attribute='name')
| list
| join(',\n')
| replace(' contact', '')
The sensor always works but every so often I get a warning like:
2023-09-10 19:53:52.927 WARNING (MainThread) [homeassistant.components.template.template_entity] Template loop detected while processing event: <Event state_changed[L]: entity_id=binary_sensor.hive_heating_doors_windows_open, old_state=<state binary_sensor.hive_heating_doors_windows_open=on; influence=Kitchen doors,
In the above case, the number of doors/windows opened goes from 2 to 3.
Is this self-referencing because it is both a binary_sensor
and it begins with states.binary_sensor
Is there anything I could/should do about it?
tom_l
September 11, 2023, 9:51am
2
Yes it is.
Have you tried rejecting the template binary sensor from your template?
EDIT: actually, are you sure that is/should be a template binary sensor and not a template sensor?
It appears to be returning a count, which is not a binary state.
jchh
((not John))
September 11, 2023, 10:57am
3
Thanks for replying!
No, I haven’t as I assumed it was effectively being rejected via the use of:
…do I need to explicitly reject it? …I’ll give that a go, thanks.
Yes, I was trying to get a binary_sensor
with the principle that a count of 0
is off
and any positive integer is on
. Is that bad coding?
tom_l
September 11, 2023, 10:59am
4
jchh:
Is that bad coding?
Nope. As long as that’s what you were after it is fine.
tom_l
September 11, 2023, 11:00am
5
jchh:
Hmmm. Yeah that should have rejected it.
jchh
((not John))
September 11, 2023, 11:03am
6
Thanks again.
Should I just ignore the warning when it crops up?
petro
(Petro)
September 11, 2023, 11:28am
7
The warning will appear regardless because you’re using the states
function, which will access the state object and trigger the warning.
Personally, I make an automated group that does this periodically and use the group in my template sensors.
- alias: Make Group
.... add whatever trigger you want
- service: group.set
object_id: doors_and_windows
entity_id: >
{{ states.binary_sensor | map(attribute='entity_id')
| select('search', '(doors?|window)_contact')
| reject('search', 'bedroom_[a-z,1]|ensuite|front')
| list }}
then just use that group in your template sensors
state: >
{{ state_attr('group.doors_and_windows','entity_id') | select('is_state', 'on') | list | count }}
attributes:
influence: >
expand('group.doors_and_windows')
| list
| join(',\n')
jchh
((not John))
September 11, 2023, 12:07pm
8
Thanks!
Other than avoiding the template loop is there an additional advantage that the group is only updated periodically whereas my sensor was being updated all the time (I’m thinking CPU load etc)?
petro
(Petro)
September 11, 2023, 12:10pm
9
Yes, if you go states.<domain>
routine in a template entity, it will only update at most once per second. If you go the group route, it will update whenever there is an update. Minor difference in this regard. If you just use states
in your template, the template is throttled to at most 1 update per minute.
jchh
((not John))
September 11, 2023, 12:23pm
10
Doesn’t it update according to the trigger?
petro
(Petro)
September 11, 2023, 12:50pm
11
the group updates according to the trigger in the automation. But we aren’t talking about that, we are talking about the template sensor that uses the group.
jchh
((not John))
September 11, 2023, 1:03pm
12
ugh, sorry. I was being dumb thinking the automation was a template sensor with a trigger.
folks, sorry to resurrect this.
I do have the same log error, although I’m excluding it, will it still log if I’m initally fetching it? I’m certain that I’m not using it, otherwise the value would keep increasing exponentially, which isn’t the case.
% set power_sensors =
states.sensor
| rejectattr('entity_id', 'equalto', 'sensor.total_w_consumption')
| selectattr('attributes.unit_of_measurement', '==', 'W')
| selectattr('attributes.device_class', '==', 'power')
| map(attribute='state')
| select('is_number')
| map('int')
| sum
{{ power_sensors }}
Got it! I though it was due to it being referred.
Are you aware of any good solution for that?
petro
(Petro)
August 6, 2024, 5:51pm
16
Yes, the post marked as a solution gets rid of the warning
petro:
expand
The expand did the trick! Thanks for your help!
