After every release my long-running HA is not liking the syntax yaml because they keep messing with it. I have given a new try at the new template syntax. It stopped complaining on the preliminary check but it doesn’t show up as a sensor. What am I doing wrong here:
I’m trying to put this into a mini-graph-card HAC plugin. It worked fine until today when I updated using the legacy method. I’m trying to make it a sensor for the purposes of displaying a graph on the gui. The code is near the end of the configuration yaml block
Ok I found helper->group-> added all six subsensors but it does not seem to be summing them all, just like the first one or two even though all 6 are in there. The good news is that the mini-card grapher is seeing it again. It’s just not summing correctly or at all
