I’m working on my first blueprint. I’ve maybe picked something too complicated, but my ultimate goal is simplify deploying a pair of automations to a group of light switches. What I would love to have in my blueprint is a selection of multiple switches and it automatically applies the pair of automations to each light, though I can understand if I need to have one blueprint per automation.
Automation 1 as YAML:
alias: Bedroom light to full if tapped on second time
description: ""
- platform: device
device_id: 46f9d5ed0404431987790ee034b8cd95
domain: zwave_js
type: event.value_notification.central_scene
property: scene
property_key: "002"
endpoint: 0
command_class: 91
subtype: Endpoint 0 Scene 002
condition:
- condition: device
type: is_on
entity_id: light.master_bedroom_light
domain: light
for:
hours: 0
minutes: 0
seconds: 1
- type: turn_on
domain: light
brightness_pct: 100
enabled: true
mode: single
Automation 2 as YAML
alias: Bedroom light to low if tapped off second time
description: ""
- platform: device
domain: zwave_js
property: scene
property_key: "001"
endpoint: 0
command_class: 91
subtype: Endpoint 0 Scene 001
condition:
- condition: device
type: is_off
domain: light
for:
hours: 0
minutes: 0
seconds: 1
- type: turn_on
domain: light
brightness_pct: 25
enabled: true
mode: single
My current attempt at just blueprinting automation 1 with the input of a single light switch
blueprint:
name: Light to full when turned on again
description: Pressing the on button of a light switch will set the light to full brightness
domain: automation
input:
target_light:
description: The light switches to add shortcuts to (currently only supports Inovelli Red switches)
selector:
entity:
domain: light
trigger_variables:
target_light: !input target_light
target_light_device_id: "{{ device_id(target_light) }}"
- platform: device
entity_id: !input 'target_light'
device_id: "{{ target_light_device_id }}"
domain: zwave_js
property: scene
property_key: "002"
endpoint: 0
command_class: 91
variables:
- type: turn_on
domain: light
brightness_pct: 100
enabled: true
When I try to create an automation based on this template I get this error:
It seems like the template that uses the variable isn’t being evaluated out. Since this is my first blueprint I’m sure I’m making a silly error. Anything standing out to anyone?
You cannot transfer the value of an input directly into a template. You have to use a variable for that.
But in this case, you can use a device selector instead and then you don’t need all the conversions you are doing.
Try something like this:
blueprint:
domain: automation
input:
target_light:
selector:
device:
domain: light
integration: zwave ### please change to the right name of zwave integration
- platform: device
device_id: !input target_light
domain: zwave_js
property: scene
property_key: "002"
endpoint: 0
command_class: 91
- service: light.turn_on
brightness_pct: 100
You probably can use multiple devices on your input, so you don’t need one automation per light but in that case you will have to change the call for the light.turn_on service and play with the trigger variable as that one probably contains the entity or device triggering the event.
Try to explain better what you are trying to achieve with your automation (specially what is your trigger) and we can try to help more.
Thanks for the suggested edit. Changing to the light.turn_on service got me further as I can keep it all in the device_id.
For my automation, I want to be able to press the “on” button on my light switch while the light is already on but not at full brightness to cause the light to go to full brightness. When I press the “off” button and the light is already off, I want it to turn on to a dim setting around 25% (Ideally this is configurable in the blueprint too).
I suspect these will have to be 2 different blueprints, one for the on button and one for the off button, but I’m hoping to be proven wrong there.
I don’t see a problem about having the 2 commands in a single blueprint. You can use Trigger Id and choose action to have your blueprint adapting to the button pressed.
But before going to that direction, let me understand better your trigger. You mentioned you have a switch to turn in the light… Could you please share the model you are using or maybe the entities (if any) you have available for that device (a screenshot?).
I have also started on the condition required for Automation 1. This is needed so pressing the “on” button when the light is off doesn’t fire the action.
blueprint:
domain: automation
input:
target_light:
selector:
device:
entity:
domain: light
- platform: device
domain: zwave_js
property: scene
property_key: "002"
endpoint: 0
command_class: 91
variables:
target_light: "{{ trigger.event.data.device_id }}"
target_light_entity_id: "{{ device_entities(target_light) | select('match', 'light') | first }}"
condition:
- condition: device
type: is_on
device_id: "{{ target_light }}"
domain: light
for:
hours: 0
minutes: 0
seconds: 1
brightness_pct: 100
- service: notify.bens_devices
message: "{{ target_light_entity_id }} {{ trigger.event.data.device_id }}"
This works, but I have the condition’s entity_id hard coded. If I swap that out to "{{ target_light_entity_id }}" I get an error:
Message malformed: Entity ID {{ target_light_entity_id }} is an invalid entity ID for dictionary value @ data['entity_id']
Putting that same "{{ target_light_entity_id }}" into a notification shows the expected value of light.master_bedroom_light, so I know my variable is being populated correctly. So for some reason the device_id is fine with a template but entity_id seems to not be.
You should avoid working with entity_id and device_id for the same item. It is possible, but why not choosing the easier path?
I would always chose the entity_id as the device_id are not under your control (and can be an issue when you replace a device).
So, I would try something like this:
blueprint:
domain: automation
input:
target_light:
selector:
entity:
domain: light
## You can capture any event from this device to trigger your automation
- platform: event
event_type: zwave.scene_activated
event_data:
entity_id: !input target_light
- choose:
- conditions: # when the up button was pressed with the lights on
- "{{ trigger.event.data.scene_id == 2 }}" #up button pressed
- condition: state
state: "on"
sequence:
brightness_pct: 100
- conditions: # when the down button was pressed with the lights off
- "{{ trigger.event.data.scene_id == 1 }}" #down button pressed
- condition: state
state: "off"
sequence:
brightness_pct: 10
# I believe you will remove this notification with the final version, but if you want to keep add an if..then to only send notifications with the selected events.
I don’t have a device like yours, so I cannot duplicate your case, but usually you can filter the event by whatever you want, so you can choose between device or entity. I will always go with entities if possible.
If you have to use both then I agree you should yse the variables as you tried, otherwise I will pick one (device or entity) and try to work only with that one. The service to turn on the light is flexible enough for your choice.
Looking in the developer tools events section, if I set it to listen to * events, the only event that seems to relate to my switch mentions the device_id but not the entity_id.
event_type: zwave_js_value_notification
domain: zwave_js
node_id: 17
home_id: 3552647087
endpoint: 0
command_class: 91
command_class_name: Central Scene
label: Scene 002
property: scene
property_name: scene
property_key: "002"
property_key_name: "002"
value: KeyPressed
value_raw: 0
origin: LOCAL
time_fired: "2023-02-25T03:00:17.210591+00:00"
context:
parent_id: null
user_id: null
I will see if I can get the condition working with only the device_id.
Okay, I’ve got it working for a single switch. Since I can’t seem to use a template for entity_id and I can’t use the device_id() filter in the limited templates used by trigger variables, I set the trigger to be any Z-Wave button press and then added a condition to confirm its device ID matches the one for the user provided entity.
blueprint:
domain: automation
input:
target_light:
selector:
entity:
domain: light
- platform: event
event_data:
value: KeyPressed
variables:
triggered_light: "{{ trigger.event.data.device_id }}"
target_light_entity_id: "{{ target_light }}"
condition:
- "{{ trigger.event.data.device_id == device_id(target_light) }}"
- choose:
- conditions:
- "{{ trigger.event.data.property_key | int == 2 }}" #up button pressed
- condition: state
state: "on"
sequence:
brightness_pct: 100
- conditions:
- "{{ trigger.event.data.property_key | int == 1 }}" #down button pressed
- condition: state
state: "off"
sequence:
brightness_pct: 10
The next tricky bit will be adding multiple different switches to a single automation. I guess I would have to map the entity IDs to their corresponding device IDs, confirm the device ID is in the list, then somehow get the state of the entity without using templates…
I’m open to suggestions there, but I probably need to file a bug report.
