Hi, need some template help. I’m trying to create a template that extracts the tire pressure from a set of attributes. Here’s what I used:
car_tire_pressure_rear_left:
friendly_name: Tire pressure Rear Left
value_template: '{{ (states.binary_sensor.mycar_tire_warning.attributes.tirepressureRearLeft / 6.89) | round (1) }}'
The problem is that the result is just showing off. This has happened to me elsewhere as well, like when trying to retrieve data from the last text message, I just get off, which is of no use to me. What am I doing wrong. The odd thing is it works perfectly when I use the template generator/tester but when I implement it in yaml it doesn’t work. Any help is appreciated!
