Template not working and I don't see what's wrong
I have multiple cameras named cam1, cam2 etc. and for each camera I have a switch called switch.CAMERA_NAME_recordings. A variable named camera stores the name of the camera (cam1, cam2 …). I’m trying to use a template to replace a longer if then else block:
So, replace this
  variables:
    camera: "{{ trigger.payload_json['camera'] }}"
                  {% if camera == 'cam1' %}
                    {% if is_state('switch.cam1_recordings','off') %}
                    {% else %}
                    {% endif %}
                  {% elif camera == 'cam2' %}
                    {% if is_state('switch.cam2_recordings','off') %}
                    {% else %}
                    {% endif %}
with this:
                {% if is_state('switch.{{camera}}_recordings','off') %}
                {% else %}
                {% endif %}
But this does not work.
Don’t nest templates like {{ ... {{var}} }}, just use the variable as-is {{ ..... var }}.
In your case you will need to concatenate the three parts to “build” the entity ID string:
{% set switch = 'switch.'~camera~'_recordings' %}
{% if is_state(switch, 'off') %}
{% else %}
{% endif %}
Cool. Thank you very much!
