Template query with array
No one is interested in your sensor :slight_smile: But… with this one I meant
{% set ts_now = ((as_timestamp(now())/1800)|round(0,'floor')|int * 1800) %}
        {{ state_attr('sensor.octopus_energy_electricity_14e0453806_1900013341923_current_rate', 'rates')
Here.
Very weird indeed, what version of HA are you on?
Home Assistant 2023.2.5
Supervisor 2023.01.1
Operating System 9.5
Frontend 20230202.0 - latest
Thx… I am raising this on discord now, I know of a guy who may shed more light…this is beyond me
Many thanks - I’m concurrently at my daughter’s birthday party but should be able to jump on discord in an hour…
I woke up my HAOS dev stuff and updated it to belwo (same)…and also there…no issues …so let’s hope discord brings help
Have a look here…posisbly a bug Temple attribute with list not created nicely - Configuration - Home Assistant Community (home-assistant.io)
Thanks, and thanks once again for your help. I am sorry it was so complicated.
I (rather stupidly, and through my own poor decision making) was somewhat distracted from my daughters birthday party because of this!
Do you think I should try and raise it as a bug somewhere?
What’s curious is that:
          | selectattr('rate', 'equalto', 23.037 )
          | map(attribute='from') | first }}
using the rate to look up the from time works and returns:
2023-02-19 00:00:00+00:00
You should raise it I would say… and refer also to the other case.
on the other curious thing… I cannot tell as I have none of your issues
Got feedback from TheFes (one mentioned)
That's indeed a python datetime tuple. You can use .isoformat() to convert it to a string. Then you need to use as_datetime to use it as a datetime again
As I have no example, cannot help at all
Oh, hey - the comments in the other thread, in particular from @123 along with this comment you gave me have me here:
{% set dt_required = (as_datetime((as_timestamp(now())/1800)|round(0,'floor')|int * 1800)) %}
          | selectattr('from', 'equalto', dt_required ) | map(attribute='rate') | first}}
This works!!!
Thanks so much!
Good but still does not explain why the other one worked for me…anyhow…moving on :slight_smile:
I believe you can streamline the template that gets the current time in ISO format. You should also append a default filter, in the rare case there’s no match found.
{% set t_now = utcnow().replace(minute=0, second=0, microsecond=0).isoformat() %}
  | selectattr('from', 'equalto', t_now)
  | map(attribute='rate') | first | default('') }}
So you did look at it :slight_smile: … now… why oh why does my template work with the same (old/original) code and James’ not? Is it possibly a formatting within the sensor when I copied the data into it?
EDIT: not asking more time …just if-you-know (have an idea)
FWIW, I saw the Issue that jamesking posted in the Core repository. I thought the Issue’s example wasn’t optimal so I revised it, tested it on the sample of data posted in the Issue and confirmed it worked.
I was going to post my working example in the Issue but then noticed it contained a link to this topic (which I never read). Anyway, as far as I’m concerned, the Issue is reporting a non-existent bug.
