I started to get an error message about a template syntax error but… the code doesn’t exist anywhere. I have remove any old code, I have search all files (hidden or not) in all home assistant directory (even .storage) but to no avail. Restart also didn’t help. I can’t understand how to clean up this.
Any help?
I was also thinking the same but the template editor has a different code for testing.
Btw: I’m aware that it is from Mushroom cards but… that cards/badge doesn’t exist anymore. I remove them all from all dashboards.
2024-09-17 12:12:21.793 ERROR (MainThread) [homeassistant.helpers.event] Error while processing template: Template<template=({% set temp=states(entity) %}
{% if temp > 26 %}
red
{% elif (temp <= 26 && temp >= 23) %}
orange
{% elif temp < 26 %}
green
{% endif %}) renders=248>
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 547, in ensure_valid
self._compiled_code = self._env.compile(self.template)
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 3113, in compile
compiled = super().compile(source)
File "/usr/local/lib/python3.12/site-packages/jinja2/environment.py", line 768, in compile
self.handle_exception(source=source_hint)
File "/usr/local/lib/python3.12/site-packages/jinja2/environment.py", line 939, in handle_exception
raise rewrite_traceback_stack(source=source)
File "<unknown>", line 4, in template
jinja2.exceptions.TemplateSyntaxError: unexpected char '&' at 74
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 715, in async_render_to_info
render_info._result = self.async_render( # noqa: SLF001
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 597, in async_render
compiled = self._compiled or self._ensure_compiled(limited, strict, log_fn)
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 796, in _ensure_compiled
self.ensure_valid()
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 549, in ensure_valid
raise TemplateError(err) from err
homeassistant.exceptions.TemplateError: TemplateSyntaxError: unexpected char '&' at 74
Where? As I mention in OP I searched every single text file in all directories, hidden or not and there is no such code. The python error also doesn’t help additionally for the location.
well… no. I removed all mushroom badges that had this code, I remove even the buttons that I copied the code. Except if there is something in binary data
It could also be as @koying writes.
Since a lot of updates ago, each browser tab remembers the template that is on it so any browser tab or device that has used this code in template editor will cause this error.
True but the moment that I post the error, I had one tab and the template editor has a completely different error. I will try to remove cookies if could be something.
Hi! Currently struggling with the same issue and was wondering whether you managed to figure this one out?
Transitioning my smart home from OpenHAB to HA, and have now started to run into the same issue, plenty of error messages from old versions of template conditions, which I changed a couple of days ago already, and have restarted system multiple times since. (And, coincidence or not, mushroom-template-cards in my case).
The cards work as intended, but the errors are spamming my logs.
