epiniguin
(Evgeny Pinigin)
July 8, 2018, 3:04pm
1
Hi!
I created an automation with service_template. The automation works but in the log there is “Template rendered invalid service:” without any additional info.
Is it a bug or my configuration error?
This is my automation:
- action:
- data:
entity_id: switch.vent_podval
service_template: >-
{% if (states('sensor.podval_humidity') | float) > 70 %}
switch.turn_on
{% elif (states('sensor.podval_humidity') | float) < 68.5 %}
switch.turn_off
{% endif %}
alias: vent_podval
condition:
- condition: state
entity_id: input_boolean.vent_podval_manual
state: 'off'
- entity_id: sensor.podval_humidity
platform: state
- event: start
platform: homeassistant
Remove the last double-quote character at the end of the template.
Also you have no service if between 68.5 and 70. That’s the bigger problem.
epiniguin
(Evgeny Pinigin)
July 8, 2018, 3:53pm
4
It was copy-paste error in my post. At the server conf it is OK. I wrote that this automation works without problem - there is error at the log only.
It is for hysteresis. If the humidity is between 68.5 and 70 nothing to do - the switch state doesn’t change
Then add a condition so it doesn’t run for those in between values, because the errors you are seeing are probably due to it running then but there’s no else so there’s no service specified.
Specifically, like this:
- action:
- data:
switch.turn_on
{% else %}
switch.turn_off
{% endif %}
alias: vent_podval
condition:
- condition: state
state: 'off'
- condition: or
conditions:
- condition: numeric_state
above: 70
below: 68.5
platform: state
- event: start
Actually, the more I think about it, maybe change the trigger instead:
- alias: vent_podval
- platform: numeric_state
above: 70
below: 68.5
- event: start
condition:
- condition: state
state: 'off'
switch.turn_on
{% else %}
switch.turn_off
{% endif %}
I also reordered the lines to be more readable.
