Template renders true but condition fails
Hi there!
I am trying to do an automation for the vacuum that triggers when no one is home but only works if the latest cleaning was more than 1 day ago. For that I am using a template condition that compares the last cleaning time to the present. This renders True in the development tools but fails the condition in the automation. I don’t understand what is happening. Can anyone point me in the right direction? Thank you!
Here is the automation as yaml but I configured in the UI.
- id: '1637149994764'
  alias: Aspirador cuando no hay nadie en casa
  description: ''
  - platform: state
    entity_id: group.home
    to: not_home
  condition:
  - condition: template
    value_template: '''{{ (as_timestamp(now()) - as_timestamp(states(''sensor.robot_aspirador_last_clean_end''))
      | int > 86400)}}'''
  - service: vacuum.start
      entity_id: vacuum.robot_aspirador
    value_template: "{{ (as_timestamp(now()) - as_timestamp(states(''sensor.robot_aspirador_last_clean_end''))
      | int > 86400)}}"
Dunno where the tripple ’ came from
That was it! I wrote the template with one ’ in the UI when it should be blank as it automatically writes it. That’s why it was duplicated. Thanks!
