I’m using a template as the Smartthing washer I’m integrating in HA is “missbehaving” for the remaining time.
It is always restarting a “3 hours” countdown while the machine is off. So I did a template like so (in configuration.yaml):
And here is the issue.
When the machine is not running, it is displaying the correct ‘-’
But when before, the entity sensor.washer_completion_time was showing as “1 hour 26 minutes”, now it is showing as "2021-07-27T17:48:57Z’
which is not what I wanted to do in the template, I wanted to return the “usual, recognized by HA” value if the other sensor’s value is not ‘none’
Should I remove the states(’’) surrounding the sensor’s value? If so, how?
Maybe using a unit_of_measurement? Which one? I don’t know, I’m lost.
Don’t forget the “else true” on the availability.
And you don’t need the if on the value, this way. The value shouldn’t be read if the entity is unavailable.
Be lucky if they don’t just straight up remove your washer and dryer entities from being exposed to HA at all. I spend $2K+ on Washer and Dryer and I am literally only able to control them through the stupid Smart Things app. I get 0 automations in Smart Things, so I can’t even use it to create a virtual switch entity and expose that. Nope. Never buying another Samsung Appliance. Honestly considering ditching the phone too. I have paid that company too much money for them to REMOVE the entities I had with an update. I’m sure updates are supposed to improve products, not make me regret going with the company in general.
It is still working, for now, knock on wood.
But I have to admit that for the price, removing functionality is pain in the a$$
The SmartThing integration is really not the best but as I did not buy the machine for that specific functionality, I’m happy with what I managed to get at the end, including a graph of my consumption, like this one:
Lol, rub it in huh? Just playin.
I did buy mine for the functionality, which made it worse. I had it for about 6 months. I had a routine that would allow it to be triggered at 8 pm if smart switch was on. Our electric bill in Texas was set up so that between 8PM and 6AM was free. So, we’d throw a load in, not start it, and let it start itself. Was so convenient.
