Gday All,
I am building a package for estimating power draw on all my devices.
One thing that would really help this, and i am sure many other template sensors, is if i had access to the variables passed in the entity_id
Given that a lot of the time we want the sensor to update based on the entity_id anyway, being able to access it will reduce potential errors, as well as clean up a lot of code.
e.g. how awesome would it be to be able to use a quick sensor like this to add the values of a bunch of sensors.
sensors:
my_summing_sensor:
friendly_name: "Sum Entities"
entity_id:
- sensor.sensor_one
- sensor.sensor_two
- sensor.sensor_three
value_template: >-
{{ expand('entity_id') | map(attribute='state') | map('float') | sum }}
Or if you could run a loop through a bunch of entities in the entity_id
list and do something?
Cheers!
