Hi there,
Trying to extract the hourly electricity prices for MY provider from a rest sensor that spits them out for ALL available providers.
{% set ns = namespace(datum='', prijs='') -%}
{% for i in states.sensor.enever_stroomprijs_vandaag.attributes.data %}
{% set ns.datum = ns.datum + i.datum %}
{% set ns.prijs = ns.prijs + i.prijsZP %}
{% endfor %}
{{ ns }}
What I would like to see is a list like so (nicely paired):
datum: '2023-02-06 00:00:00’, prijs: '0.330898'
datum: '2023-02-06 01:00:00', prijs: '0.329361'
datum: '2023-02-06 02:00:00’, prijs: '0.331430'
etc.
What I am getting from the template above is:
<Namespace {'datum': '2023-02-06 00:00:002023-02-06 01:00:002023-02-06 02:00:002023-02-06 03:00:002023-02-06 04:00:002023-02-06 05:00:002023-02-06 06:00:002023-02-06 07:00:002023-02-06 08:00:002023-02-06 09:00:002023-02-06 10:00:002023-02-06 11:00:002023-02-06 12:00:002023-02-06 13:00:002023-02-06 14:00:002023-02-06 15:00:002023-02-06 16:00:002023-02-06 17:00:002023-02-06 18:00:002023-02-06 19:00:002023-02-06 20:00:002023-02-06 21:00:002023-02-06 22:00:002023-02-06 23:00:00', 'prijs': '0.3308980.3293610.3314300.3274250.3249690.3356530.3680090.3982340.4136500.3982100.3793950.3533310.3125060.3122030.3193790.3364640.3754260.3961650.4137830.4039580.3807620.3568890.3399730.341788'}>
so first all dates and then all prices…
Help!
Troon
(Troon)
February 6, 2023, 11:32am
2
(removed, as I’ve been corrected below )
petro
(Petro)
February 6, 2023, 11:38am
3
{% set ns = namespace(items=[]) -%}
{% set ns.items = ns.items + [ {'datum': i.datum, 'prijs': i.prijsZP} ] %}
{% endfor %}
{{ ns.items }}
petro
(Petro)
February 6, 2023, 11:40am
4
You can build a dictionary using dictionary methods: <dict>.from_keys(...)
, or <dict>.fromkeys(...)
. Or using the literal dict
I have examples all over the forums as replies for different ways to make a dictionary from scratch. Or append items to a dictionary. Or adding keys to a dictionary.
You can also take advantage of **items
in combination w/ the methods I mentioned above.
make a list of kevalue pairs:
{% set kvps = [('x', 1), ('y',1)] %}
then create your dictionary. You will not be able to update an existing dictionary with .update({})
{% set data = dict.from_keys(kvps) %}
Your best option to ‘update’ an existing dictionary (current) with another dictionaries values (update)…
{# make current a list of tuples #}
{% set current = current.items() | list %}
{# make update a list of tuples #}
{% set update = update.items() | list %}
{# remove keys from current …
This can be easily done by creating a new dict in this way:
{% set my_dict = dict(a=1, b='b') %}
{% set my_dict = dict(my_dict.items(), a="one", c=3.14) %}
Which correctly generates:
{'a': 'one', 'b': 'b', 'c': 3.14}
That method does not allow for variable key names unless you provide 2 dictionaries.
EDIT: 2 dict method…
{% set my_dict = dict(my_dict.items(), **otherdict) %}
Super! Many thanks for the quick response and elegant solution! Works like a charm.
Final template sensor now looks like this:
sensors:
zonneplan_stroom_prijs:
friendly_name: "Zonneplan Stroomprijs"
unit_of_measurement: €/kWh
device_class: monetary
value_template: >-
{% set t = now().hour %}
{% set prijs = state_attr('sensor.enever_stroomprijs_vandaag', 'data')[t].prijsZP | float %}
{{ prijs }}
attribute_templates:
hourly: >-
{% set ns = namespace(items=[]) %}
{% endfor %}
{% for i in states.sensor.enever_stroomprijs_morgen.attributes.data %}
{% endfor %}
{{ ns.items }}
And a nice graph based on this sensor:
with code as follows:
type: custom:apexcharts-card
experimental:
color_threshold: true
graph_span: 48h
span:
start: day
now:
show: true
label: Now
yaxis:
- id: first
min: -0.1
max: 0.8
decimals: 3
apex_config:
tickAmount: 9
header:
show: true
title: Zonneplan (enever) 48h (€/kwh)
series:
- entity: sensor.zonneplan_stroom_prijs
stroke_width: 2
float_precision: 3
type: column
opacity: 1
data_generator: |
return entity.attributes.hourly.map((record, index) => {
return [record.datum, record.prijs];
color_threshold:
- value: 0.2
color: lightgreen
- value: 0.25
color: green
- value: 0.3
color: blue
- value: 0.35
color: orange
- value: 0.4
color: red
