Hi everyone,
I need help modifying the following template sensor to remove from the attribute devices, the duplicate entries which have the same MAC/IP, and node c8:7f:54:a1:c9:d8.
- sensor:
- name: Asus Connected Devices
unique_id: asus_connected_devices
state_class: measurement
icon: mdi:router-network
state: >
{{ states('sensor.router_connected_devices') }}
attributes:
devices: >
{% set router_devices_list = state_attr('sensor.router_connected_devices', 'devices') | default([]) %}
{% set kitchen_ap_devices_list = state_attr('sensor.kitchen_ap_connected_devices', 'devices') | default([]) %}
{% set bathroom_2_ap_devices_list = state_attr('sensor.bathroom_2_ap_connected_devices', 'devices') | default([]) %}
{% set combined_list = router_devices_list + kitchen_ap_devices_list + bathroom_2_ap_devices_list %}
{% for device in combined_list if device.connection_type == 'wired' or device.connected is defined %}
"mac": "{{ device.mac }}",
"ip": "{{ device.ip }}",
"name": "{{ device.name }}",
"connection_type": "{{ device.connection_type }}",
"node": "{{ device.node }}",
"guest": "{{ device.guest }}",
"guest_id": "{{ device.guest_id }}",
"connected": "{{ device.connected }}"
}{% if not loop.last %},{% endif %}
{% endfor %}
Just to give some context:
I have the following 3 sensors created by the Asus router custom integration: sensor.router_connected_devices, sensor.kitchen_ap_connected_devices and sensor.bathroom_2_ap_connected_devices and they contain the attribute devices (devices connected to the router/APs) showing the IP, MAC, name, connection type, node, connected time, etc.
The Asus firmware has a bug and the router reports as connected over Ethernet (wired) a lot of the devices which are actually connected over WiFi to the APs (the APs being connected to the router over Ethernet).
In the below example Living Room TV Presence is actually connected over WiFi to another AP, Rain Sensor is connected to the Router over WiFi, BLE Gateway 1 is connected over Ethernet to the Router.
devices:
- mac: 0c:b8:15:d5:c0:54
ip: 192.168.45.120
name: Living Room TV Presence
connection_type: wired
node: c8:7f:54:a1:c9:d8
- mac: e8:68:e7:c7:e1:06
ip: 192.168.45.101
connection_type: 2ghz
guest: false
guest_id: 0
connected: "2024-06-17T07:29:07+00:00"
- mac: e8:68:e7:c1:8c:cd
connection_type: disconnected
- mac: c4:5b:be:93:1e:73
ip: 192.168.45.17
name: BLE Gateway 1
friendly_name: Router Connected Devices
Thanks in advance for your help.
