Template sensor does not appear
I am quite new to HA.
I configured a sensor via Developertools/Templates. My target was to extract the attribut “current_temperature” from my heatingthermostat. (Comet DECT 700018) to use it later in automatisations.
Here’s the code:
    sensors:
    TemperaturWohn:
      entity_id: sensor.TemperaturWohn
      value_template: "{{ states.climate.comet_dect_1.attributes.current_temperature | int }}"
      feindly_name: "Temperatut Heizung"
Here what as a result is shown:
    sensors:
    TemperaturWohn:
      value_template: "23"
I restarted everything, but the sensor does not appear, if I try to add it to a lovelace.
found this, but does not realy helps me:
Can anybody help or give me advice?
thx
There was quite a bit wrong with your sensor. Try this:
    sensors:
      temperatur_wohn: # this must be lower case, and notice the indentation
        value_template: "{{ state_attr('climate.comet_dect_1', 'current_temperature') }}" # Fixed quite a few things here
        friendly_name: "Temperatur Heizung" # I don't speak German but I think this is the correct spelling
        unit_of_measurement: "°C" # this is required if you ever want to make a graph
Typo:
states() state_attr()
Fixed. Thanks.
Hi. Via /Developertools/templates it didn’t work. No error but the sensor didn’t show up.
So I copied your code to my configuration.yaml,
I received an error “Invalid config for [sensor.template]: [unit_of_measuremant] is an invalid option for [sensor.template].”
So i deleted that line and it works, even with a graph (i think so) I have to observe if it realy shows the right values.
Anyway, thanks a lot so far for your help.
Because I cant spell.
unit_of_measuremant: should be unit_of_measurement:
Sorry.
thanks for checking again. If would have payed a little bit more attention …
