i have an error:
Registratore: homeassistant.helpers.event
Fonte: helpers/event.py:330
Prima occorrenza: 14 marzo 2024 alle ore 12:38:05 (17 occorrenze)
Ultima registrazione: 14:27:24
Error while dispatching event for input_number.batteria_desiderata to <Job track state_changed event {‘input_number.batteria_desiderata’, ‘sensor.i4_edrive40_percentuale_di_batteria_rimanente’} HassJobType.Callback <bound method TrackTemplateResultInfo._refresh of <TrackTemplateResultInfo {Template<template=({% set percent_desired = states(‘input_number.batteria_desiderata’) | int %} {% set percent_current = states(‘sensor.i4_edrive40_percentuale_di_batteria_rimanente’) | int %} {% set battery_capacity = 80.3 %} {% set battery_to_charge = (battery_capacity * (percent_desired/100)) - (battery_capacity * (percent_current/100)) %} {{ ‘%0.1f’|format(battery_to_charge) }} #BATTERIA RESTANTE FOTOVOLTAICO) renders=34>: <RenderInfo Template<template=({% set percent_desired = states(‘input_number.batteria_desiderata’) | int %} {% set percent_current = states(‘sensor.i4_edrive40_percentuale_di_batteria_rimanente’) | int %} {% set battery_capacity = 80.3 %} {% set battery_to_charge = (battery_capacity * (percent_desired/100)) - (battery_capacity * (percent_current/100)) %} {{ ‘%0.1f’|format(battery_to_charge) }} #BATTERIA RESTANTE FOTOVOLTAICO) renders=34> all_states=False all_states_lifecycle=False domains=frozenset() domains_lifecycle=frozenset() entities=frozenset({‘input_number.batteria_desiderata’, ‘sensor.i4_edrive40_percentuale_di_batteria_rimanente’}) rate_limit=None has_time=False exception=None is_static=False>}>>>
Error while dispatching event for input_number.batteria_desiderata to <Job track state_changed event {‘input_number.batteria_desiderata’, ‘sensor.i4_edrive40_percentuale_di_batteria_rimanente’} HassJobType.Callback <bound method TrackTemplateResultInfo._refresh of <TrackTemplateResultInfo {Template<template=({% set percent_desired = states(‘input_number.batteria_desiderata’) | int %} {% set percent_current = states(‘sensor.i4_edrive40_percentuale_di_batteria_rimanente’) | int %} {% set battery_capacity = 80.3 %} {% set battery_to_charge = (battery_capacity * (percent_desired/100)) - (battery_capacity * (percent_current/100)) %} {{ ‘%0.1f’|format(battery_to_charge) }} #BATTERIA RESTANTE FOTOVOLTAICO) renders=36>: <RenderInfo Template<template=({% set percent_desired = states(‘input_number.batteria_desiderata’) | int %} {% set percent_current = states(‘sensor.i4_edrive40_percentuale_di_batteria_rimanente’) | int %} {% set battery_capacity = 80.3 %} {% set battery_to_charge = (battery_capacity * (percent_desired/100)) - (battery_capacity * (percent_current/100)) %} {{ ‘%0.1f’|format(battery_to_charge) }} #BATTERIA RESTANTE FOTOVOLTAICO) renders=36> all_states=False all_states_lifecycle=False domains=frozenset() domains_lifecycle=frozenset() entities=frozenset({‘input_number.batteria_desiderata’, ‘sensor.i4_edrive40_percentuale_di_batteria_rimanente’}) rate_limit=None has_time=False exception=None is_static=False>}>>>
Error while dispatching event for input_number.batteria_desiderata to <Job track state_changed event {‘input_number.batteria_desiderata’, ‘sensor.i4_edrive40_percentuale_di_batteria_rimanente’} HassJobType.Callback <bound method TrackTemplateResultInfo._refresh of <TrackTemplateResultInfo {Template<template=({% set percent_desired = states(‘input_number.batteria_desiderata’) | int %} {% set percent_current = states(‘sensor.i4_edrive40_percentuale_di_batteria_rimanente’) | int %} {% set battery_capacity = 80.3 %} {% set battery_to_charge = (battery_capacity * (percent_desired/100)) - (battery_capacity * (percent_current/100)) %} {{ ‘%0.1f’|format(battery_to_charge) }} #BATTERIA RESTANTE FOTOVOLTAICO) renders=38>: <RenderInfo Template<template=({% set percent_desired = states(‘input_number.batteria_desiderata’) | int %} {% set percent_current = states(‘sensor.i4_edrive40_percentuale_di_batteria_rimanente’) | int %} {% set battery_capacity = 80.3 %} {% set battery_to_charge = (battery_capacity * (percent_desired/100)) - (battery_capacity * (percent_current/100)) %} {{ ‘%0.1f’|format(battery_to_charge) }} #BATTERIA RESTANTE FOTOVOLTAICO) renders=38> all_states=False all_states_lifecycle=False domains=frozenset() domains_lifecycle=frozenset() entities=frozenset({‘input_number.batteria_desiderata’, ‘sensor.i4_edrive40_percentuale_di_batteria_rimanente’}) rate_limit=None has_time=False exception=None is_static=False>}>>>
Error while dispatching event for input_number.batteria_desiderata to <Job track state_changed event {‘input_number.batteria_desiderata’, ‘sensor.i4_edrive40_percentuale_di_batteria_rimanente’} HassJobType.Callback <bound method TrackTemplateResultInfo._refresh of <TrackTemplateResultInfo {Template<template=({% set percent_desired = states(‘input_number.batteria_desiderata’) | int %} {% set percent_current = states(‘sensor.i4_edrive40_percentuale_di_batteria_rimanente’) | int %} {% set battery_capacity = 80.3 %} {% set battery_to_charge = (battery_capacity * (percent_desired/100)) - (battery_capacity * (percent_current/100)) %} {{ ‘%0.1f’|format(battery_to_charge) }} #BATTERIA RESTANTE FOTOVOLTAICO) renders=40>: <RenderInfo Template<template=({% set percent_desired = states(‘input_number.batteria_desiderata’) | int %} {% set percent_current = states(‘sensor.i4_edrive40_percentuale_di_batteria_rimanente’) | int %} {% set battery_capacity = 80.3 %} {% set battery_to_charge = (battery_capacity * (percent_desired/100)) - (battery_capacity * (percent_current/100)) %} {{ ‘%0.1f’|format(battery_to_charge) }} #BATTERIA RESTANTE FOTOVOLTAICO) renders=40> all_states=False all_states_lifecycle=False domains=frozenset() domains_lifecycle=frozenset() entities=frozenset({‘input_number.batteria_desiderata’, ‘sensor.i4_edrive40_percentuale_di_batteria_rimanente’}) rate_limit=None has_time=False exception=None is_static=False>}>>>
Error while dispatching event for input_number.batteria_desiderata to <Job track state_changed event {‘input_number.batteria_desiderata’, ‘sensor.i4_edrive40_percentuale_di_batteria_rimanente’} HassJobType.Callback <bound method TrackTemplateResultInfo._refresh of <TrackTemplateResultInfo {Template<template=({% set percent_desired = states(‘input_number.batteria_desiderata’) | int %} {% set percent_current = states(‘sensor.i4_edrive40_percentuale_di_batteria_rimanente’) | int %} {% set battery_capacity = 80.3 %} {% set battery_to_charge = (battery_capacity * (percent_desired/100)) - (battery_capacity * (percent_current/100)) %} {{ ‘%0.1f’|format(battery_to_charge) }} #BATTERIA RESTANTE FOTOVOLTAICO) renders=42>: <RenderInfo Template<template=({% set percent_desired = states(‘input_number.batteria_desiderata’) | int %} {% set percent_current = states(‘sensor.i4_edrive40_percentuale_di_batteria_rimanente’) | int %} {% set battery_capacity = 80.3 %} {% set battery_to_charge = (battery_capacity * (percent_desired/100)) - (battery_capacity * (percent_current/100)) %} {{ ‘%0.1f’|format(battery_to_charge) }} #BATTERIA RESTANTE FOTOVOLTAICO) renders=42> all_states=False all_states_lifecycle=False domains=frozenset() domains_lifecycle=frozenset() entities=frozenset({‘input_number.batteria_desiderata’, ‘sensor.i4_edrive40_percentuale_di_batteria_rimanente’}) rate_limit=None has_time=False exception=None is_static=False>}>>>
File “/usr/src/homeassistant/homeassistant/components/sensor/init.py”, line 668, in state
numerical_value = float(value) # type:ignore[arg-type]
ValueError: could not convert string to float: ‘3.2\n\n #BATTERIA RESTANTE FOTOVOLTAICO’
File “/usr/src/homeassistant/homeassistant/helpers/event.py”, line 330, in _async_dispatch_entity_id_event
hass.async_run_hass_job(job, event)
File “/usr/src/homeassistant/homeassistant/core.py”, line 727, in async_run_hass_job
hassjob.target(*args)
File “/usr/src/homeassistant/homeassistant/helpers/event.py”, line 1262, in _refresh
self.hass.async_run_hass_job(self._job, event, updates)
File “/usr/src/homeassistant/homeassistant/components/template/template_entity.py”, line 434, in _handle_results
self.async_write_ha_state()
File “/usr/src/homeassistant/homeassistant/helpers/entity.py”, line 992, in async_write_ha_state
self._async_write_ha_state()
File “/usr/src/homeassistant/homeassistant/helpers/entity.py”, line 1113, in _async_write_ha_state
state, attr, capabilities, shadowed_attr = self.__async_calculate_state()
File “/usr/src/homeassistant/homeassistant/helpers/entity.py”, line 1050, in __async_calculate_state
state = self._stringify_state(available)
File “/usr/src/homeassistant/homeassistant/helpers/entity.py”, line 998, in _stringify_state
if (state := self.state) is None:
File “/usr/src/homeassistant/homeassistant/components/sensor/init.py”, line 670, in state
raise ValueError(
ValueError: Sensor sensor.batteria_macchina_da_ricaricare has device class ‘None’, state class ‘None’ unit ‘kWh’ and suggested precision ‘None’ thus indicating it has a numeric value; however, it has the non-numeric value: '3.2
#BATTERIA RESTANTE FOTOVOLTAICO’ (<class ‘str’>)
the two templates are this:
sensors:
batteria_macchina_da_ricaricare:
friendly_name: "Batteria da caricare"
unit_of_measurement: 'kWh'
value_template: >
{% set percent_desired = states('input_number.batteria_desiderata') | int %}
{% set percent_current = states('sensor.i4_edrive40_percentuale_di_batteria_rimanente') | int %}
{{ '%0.1f'|format(battery_to_charge) }}
sensors:
batteria_fotovoltaico_restante:
friendly_name: "batteria fotovoltaico restante"
value_template: "{{ (states('sensor.solarman_battery_1_soc')|float/100)*20.8 }}"
unit_of_measurement: "kWh"
