Template sensor - don't want to assume state up/down
Hi there,
I have a template cover on my Home Assistant that is using a Broadlink Rf bridge to transmit the open/close signal to my blinds.
I have no way of tracking the state of the blinds, and don’t care much for it at this time. However, Home Assistant remembers the last command sent to the blinds, and assumes the state of the blinds.
The problem is that in case anyone at home used the remote to open/close the blinds, then the remembered state will be wrong and the front end button will be greyed out and not usable.
Here is what my config looks like, any help is appreciated.
    covers:
      back_door:
        friendly_name: "Back Door"
        open_cover:
          service: switch.turn_on
            entity_id: switch.blinds_up_down
        close_cover:
          service: switch.turn_off
        stop_cover:
            entity_id: switch.blinds_stop_middle
Have you tried adding
optimistic: true
to your cover ?
Else another option would be to have an input Boolean state change trigger the scripts and it will still look like a switch.
If you’re not concerned with how it looks just group the two scripts together and you can press the ‘Activates’ to work your blinds
