Following the guide https://www.homeautomationguy.io/blog/managing-offline-devices-in-zigbee2mqtt to send notifications when Zigbee device goes off-line.
The Helper for the Template Sensor looks like:
{% set result = namespace(sensors=[]) %}
{% for state in states.sensor | rejectattr('attributes.device_class', 'undefined') | selectattr('attributes.device_class', '==', 'timestamp') %}
{% if 'last_seen' in state.entity_id and (states(state.entity_id) == 'unavailable' or ((as_timestamp(now()) - as_timestamp(states(state.entity_id))) > ((24 | int) * 60 * 60))) %}
{% set result.sensors = result.sensors + [state.name | regex_replace(find=' last seen', replace='') ~ ' (' ~ relative_time(strptime(states(state.entity_id), '%Y-%m-%dT%H:%M:%S%z', 'unavailable')) ~ ')'] %}
{% endif %}
{% endfor %}
{{ result.sensors | join('\n') | truncate(254, True) }}
- The helper works, in that it lists my entities ending with
last_seen
- The notification works when device(s) go offline (see automation in guide)
However, the template clutters my Home Assistant log with the following error message that I’m not able to parse into a fix for the above template. Hopefully someone has an idea.
2024-06-11 23:08:29.111 ERROR (MainThread) [homeassistant.helpers.event] Error while processing template: Template<template=({% set result = namespace(sensors=[]) %}
{% endif %}
{% endfor %}
{{ result.sensors | join('\n') | truncate(254, True) }}) renders=2>
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 2059, in forgiving_as_timestamp
return dt_util.as_timestamp(value)
File "/usr/src/homeassistant/homeassistant/util/dt.py", line 153, in as_timestamp
raise ValueError("not a valid date/time.")
ValueError: not a valid date/time.
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 603, in async_render
render_result = _render_with_context(self.template, compiled, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 2616, in _render_with_context
return template.render(**kwargs)
File "/usr/local/lib/python3.12/site-packages/jinja2/environment.py", line 1304, in render
self.environment.handle_exception()
File "/usr/local/lib/python3.12/site-packages/jinja2/environment.py", line 939, in handle_exception
raise rewrite_traceback_stack(source=source)
File "<template>", line 3, in top-level template code
File "/usr/local/lib/python3.12/site-packages/jinja2/sandbox.py", line 394, in call
return __context.call(__obj, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 2062, in forgiving_as_timestamp
raise_no_default("as_timestamp", value)
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 1853, in raise_no_default
raise ValueError(
ValueError: Template error: as_timestamp got invalid input 'unknown' when rendering template '{% set result = namespace(sensors=[]) %}
{% endif %}
{% endfor %}
{{ result.sensors | join('\n') | truncate(254, True) }}' but no default was specified
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 715, in async_render_to_info
render_info._result = self.async_render( # noqa: SLF001
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 605, in async_render
raise TemplateError(err) from err
homeassistant.exceptions.TemplateError: ValueError: Template error: as_timestamp got invalid input 'unknown' when rendering template '{% set result = namespace(sensors=[]) %}
{% endif %}
{% endfor %}
