I’m trying to refine an existing template binary sensor I have. I am using the hass-amplifi custom integration which returns a list of all devices connected to WiFi. From this, I am trying to create a binary sensor which is enabled when any device is connected to the Guest SSID (which feeds into a “guest mode” sensor. These devices can be identified because their IP address begins with 192.168 instead of 172.20.
Here is the current template:
{{ states.device_tracker
| selectattr('entity_id', 'match', 'device_tracker.amplifi.*')
| selectattr('entity_id','match','device_tracker.amplifi_192_168_*')
| selectattr('state', 'eq', 'home')
| list
| count
Because of how the integration names entities, sometimes the entity ID contains the IP address, sometimes it contains the MAC address. What I would like to do is find all entities where EITHER 1) “192_168” is within the entity ID or 2) the attribute “ip” contains 192.168. I was able to do the latter with this:
| rejectattr('attributes.ip','undefined')
| selectattr('attributes.ip','match','192.168.*')
| list
| count
What I can’t figure out is how I combine these two templates so that it matches either the entity ID or the IP attribute. I found this thread which uses the search function instead of match, but I don’t think this works in my case as I’m trying to filter by either one of two attributes.
I have tried the below but this does not work:
| selectattr('attributes.ip','match','192.168.*') or selectattr('entity_id','match','device_tracker.amplifi_192_168_*')
| list
| count
This returns <generator object select_or_reject at 0x7f9f808fcdc0>
which is not what I’m looking for haha. I’m assuming this is because selectattr is more like a filter than a condition.
I have considered changing this whole thing to a bunch of IF statements and potentially loops, but this solution seems so clean (and presumably is less CPU intensive) than that so I was trying to avoid it. If that is the only solution, so be it, but I thought it was worth asking here in case there was an easier way to achieve what I’m trying to do.
Thank you.
