Hi all. I try to make a template sensor and in the Template editor it’s working great.
In the ‘configuration.yaml’ I have added
template: !include_dir_list template , then make ‘sensor_name.yaml’ file in template folder. Here is the code:
- sensor:
- name: "Battery PV Percentage"
icon_template: "mdi:battery-charging-high"
unit_of_measurement: "%"
state: >
{% if states('sensor.bank_1_total_voltage') | float(0) > 28.7 %}
100
{% else %}
{{ ((states('sensor.bank_1_total_voltage') | float(0)-22.5) / 0.062) | round(0) }}
{% endif %}
When I check the Configuration Validation the result is Configuration valid!
When I check for entity ‘battery_pv_percentage’ it doesn’t exist.
Can you help me fix that, please?
