I hope someone can help me with my problem. I have created a template that sum up three sensors for my energy dashboard (see template below).
Now I have the problem that this sensor (group) gets a reset twice a day and my energy dashboard jumps from 0 to the latest value. Happens every day between 8PM-9PM and 4AM-6AM. I than manually remove this values in the statistics and everything is fine till the next day or evening.
I tried the ‘availability’ option of the template in different ways but without success. Did someone have the same problem and a solution for it?
Here are the templates which I used without success.
- sensor:
- name: pv_production_total
unique_id: "PVProductionTotal(kwh)"
state_class: 'total_increasing'
unit_of_measurement: 'kWh'
device_class: 'energy'
state: >
{% set l1 = states('sensor.victron_pvinverter_l1_energy_forward_total_20') | float %}
{% set l2 = states('sensor.victron_pvinverter_l2_energy_forward_total_20') | float %}
{% set l3 = states('sensor.victron_pvinverter_l3_energy_forward_total_20') | float %}
{{ (l1 + l2 + l3) | round(1, default=0) }}
availability: >
{{ states ('sensor.victron_pvinverter_l1_energy_forward_total_20') not in ['unknown', 'unavailable', 'None']
and
states ('sensor.victron_pvinverter_l2_energy_forward_total_20') not in ['unknown', 'unavailable', 'None']
and
states ('sensor.victron_pvinverter_l3_energy_forward_total_20') not in ['unknown', 'unavailable', 'None'] }}
and some other availability part
availability: >
{{ states ('sensor.victron_pvinverter_l1_energy_forward_total_20')| is_number and
states ('sensor.victron_pvinverter_l2_energy_forward_total_20')| is_number and
states ('sensor.victron_pvinverter_l3_energy_forward_total_20')| is_number }}
I also tried to add all three sensors separately to the energy dashboard but the presentation is not really good.
Thanks for your help
