I have the following template binary sensor defined:
- binary_sensor:
- name: "Occupancy Sensor Debounced"
unique_id: "occupancy_sensor_debounced"
state: >
is_state('binary_sensor.some_contact_sensor', 'on')
delay_on:
minutes: 2
delay_off:
minutes: 5
device_class: occupancy
After restarting home assistant, this sensor turns on, i.e. occupancy is detected. I believe this is because the delay_off
is set to 5 minutes; I have another very similar sensor, using the same contact sensor as source, without any delay_on
or delay_off
, and that one at startup works properly.
My source contact sensor at startup goes first unknown
, then transitions to off
; I would expect my template sensor to never turn on.
Can anyone help me in making this work? For me, it is acceptable to play around with the delays if it helps, or to provide some default state if possible.
Thanks for your help!
Cheers,
V
