Good evening all,
I’ve been finding an issue with the reporting coming from my battery storage. I have two batteries but only information from one is being reported. I wanted to record the difference between the two and I’ve created a template sensor.
sensors:
battery_2_discharging_rate:
unit_of_measurement: W
value_template: "-{{ states('sensor.solax_house_load') | float + states('sensor.solax_battery_power_charge') | float }}"
friendly_name: Battery 2 Discharge Rate
icon_template: mdi:flash
sensors:
battery_discharging_rate:
value_template: "{{ states('sensor.battery_2_discharging_rate') | float + states('sensor.solax_battery_power_charge') | float }}"
friendly_name: Battery Discharge Rate
However, the second sensor does not work. It comes back as unavailable. It works when I create it in Developer Tools in the Template section but when I put it into configuration.yaml and restart I get nothing. I’m clearly doing something wrong, but I am out of ideas for what it would be. The second sensor is just adding the total from the first sensor to the amount the other battery is discharging.
It’s late now, and I’m going to have to leave it for the night, but any help would be appreciated.
Thanks,
Tom
