I created a template sensor from a attribute of my climate.vicare_heating entity which is working fine. I have some different custom mini graph cards that shows the min/max value but for some reason it’s not working for my created template sensor, the history graph from the sensor is working. Hope someone can help to solve my problem.
Thanks both for the answer. About the icon I know.
Anyway i don’t get the min/max values working, keeps the same temp and time for both. Strange is that it works for all my other sensors created by default by installing add ons, etc. Also the graph history is working fine for the template attribute sensor. I think I’m missing something in the configuration.yaml but no clue what it is.
Edit: After changing the entity name of the sensor it’s working fine now. Seems that it’s needed after i changed the code in the configuration.yaml.
