I have a similary issue and tried to follow these steps, but no luck.
I want to use the sensor possible_charging_phases as an integer input for an automation, but it seems like it dosent recognize it as an integer
This is from the trace log for the automation
this is a snippet of the action sequence. Is it possible to cast this to an integer?
- conditions:
- condition: template
value_template: '{{states(''sensor.possible_charging_phases'') | int == 1}}'
sequence:
- service: easee.set_circuit_dynamic_limit
currentP1: 0
currentP2: 0
currentP3: sensor.possible_charging_power
time_to_live: 0
device_id: e58dfa2f3706cf4b5df0fca52ca75825
and finally the sensor
template:
- sensor
- name: "Possible Charging Power"
unique_id: "possibleChargingPower"
state: >
{% set currentSpareProduction = states('sensor.current_spare_production') | float %}
{% if currentSpareProduction > 4200 -%}
{{ (min(max((currentSpareProduction / (400 * 1.73)) | round(0, default=0),6),16)) | int}}
{% elif currentSpareProduction > 1000 -%}
{{ (min(max((currentSpareProduction / (240 * 1)) | round(0, default=0),6),16)) | int}}
{%- else -%}
0
{%- endif %}
Can anyone help?
