I have a couple of template sensors that sum up power, energy consumption, … over various devices. The configuration has been working for months now and has not been touched. Honestly!
Since a couple of days now, the sensors just stop recalculating for no obvious reason although new values are coming in from the underlying sensors.
what I observed / tried:
- template sensors keep their last calculated values, do not go to unknown or so
- as far as I have seen, all template sensors summing up the energy values fail at the same time
- other template sensors do still work when this occurs (I tried a simple one displaying local time)
- to get them restarted, I need to reload the YAML configuration for template entities or restart HA
- no obvious pattern when this occurs (time, events, values, …)
- nothing to be seen in the logs
- when I copy the code for state into the template editor in developer tools, the value is being correctly summed up there
here is an example of a sensor configuration:
template:
- sensor:
- name: "Gesamtleistung"
unique_id: power_total
unit_of_measurement: "W"
device_class: power
state_class: measurement
state: >
{{ states.sensor
| selectattr('entity_id', 'in', state_attr('group.power_sensors','entity_id'))
| selectattr('state', 'is_number')
| map(attribute='state') | map('float') | default (0.0) | sum }}
icon: mdi:home-lightning-bolt-outline
I’m kind of clueless at the moment and have not even a good idea how to debug that behaviour. Any ideas around?
